Did you know? 🤔
Water under drivers seat back passenger floor
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
Litty
Year and Model: 2005 S40
Has thanked: 0
Been thanked: 0
Litty
Post by Litty » Tue Mar 06, 2012 5:46 am
The floor on the passengers side behind the drivers seat is very wet, we have mopped it up on several occasions over the last 4 days and then today removed about half a bucket of water with a vacuum. Is this possibly a blocked air con pipe? Also noticed the air con water is not dripping out the bottom of the car when you park. Where would I locate the air con drain pipe so that I can check if it is this that is blocked? Could it be anything else causing this problem - there is no sun roof.
fazool
Year and Model: S60, 2007
Has thanked: 0
Been thanked: 4 times
United States of America
fazool
Re: Water under drivers seat back passenger floor
Post by fazool » Tue Mar 06, 2012 10:09 am
Litty wrote:The floor on the passengers side behind the drivers seat is very wet.
What model and what year is your car? How old is it? RHD or LHD ?
Litty wrote:Is this possibly a blocked air con pipe? Also noticed the air con water is not dripping out the bottom of the car when you park. Where would I locate the air con drain pipe so that I can check if it is this that is blocked? Could it be anything else causing this problem - there is no sun roof.
That's a good line of thinking. Obvious, but necessary question, you can rule out rain, right ?it's not rain, right ?
If you run your car with A/C on and let it sit still and there is no puddle underneath (if its real hot outside that is) and if you have no rain recently, I think you found your source - a plugged A/C drain hose.
I read another S40 owner had a blocked A/C drain and the water collected and was blown under the driver seat through the heat ducts and drenched the rear floor.
So, check the air vents under the seats - inside they are probably running water (with A/C on) - this will confirm the source.
2007 S60 2.5T AWD (Daily Driver)
2001 S60 2.4T (Daughter's Car)
2003 S80 2.9 (Son's Car)
1995 850 2.4 (Daughter's Car - sold off)
2005 S40 2.4i (Bought new - since sold)
1986 740GLE 2.3(First Volvo - sold off)
fazool
Has thanked: 0
fazool
Post by fazool » Tue Mar 06, 2012 10:11 am
Looks like a common problem with (as you suspected) a faulty A/C drain line
read this
http://www.volvo-forums.com/t19605-water-leak.htm
osman
Year and Model: 2002 c70 hardtop
Has thanked: 0
Been thanked: 0
Algeria
osman
Post by osman » Tue Mar 06, 2012 2:36 pm
your heater core could be leaking
Brick Life
2003 Saab 9-5 ARC V6 3.0 Turbo 120K SwagWagon
97 850R wagon mileage unknown
2000 C70 Turbo Convertible 110K
99 XC70 AWD LPT 115
98 BMW 328IS 130K M3 Wheels
94 Mercedes 420E 160K
Kiwi bluetooth/Torq Pro app VOL-FCR/VAG-COM USB cable
fazool
Has thanked: 0
fazool
Post by fazool » Tue Mar 06, 2012 2:44 pm
Yes. Good point.
Is the liquids clean water or is it sweet slippery like engine coolant?
Is your coolant tank down any fluid ?
Qanonim
Year and Model: S40 2005
Has thanked: 0
Been thanked: 0
Qanonim
Post by Qanonim » Thu Jun 13, 2019 2:13 am
Where is placed drain pipe from ac.
