windshield wiper question
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
randalls350
Year and Model: 240 1986
Post by randalls350 »
The windshield wipers froze to the windshield during a cold spell here recently, I didn't pull the wipers away from the windshield as I usually do in the evening if there is potential for freezing. In the morning when I went out to go to work, without thinking I turned on the windshield wipers before the windshield was fully defrosted....before I knew it the wipers were thrown off. Now the wipers stop in the middle of the windshield instead of stopping in the full position down. My question is, do I need to replace the wiper bearings or the motor? I thought perhaps the teeth on the wiper arm where it mounts to the bearing striped or the bearing itself. How do I fix this? Aaarrrgh!
fazool
Year and Model: S60, 2007
Been thanked: 7 times
Post by fazool »
Its likely an easy fix:
It depends on your model and year but generally speaking there is a tapered shaft that rotates. This will have grooves in it to increase the grip of the shaft when moving the arm. There is a nut that pulls the arm down over these grooves and pulls everything together.
Its common and likely that these simply slipped when they saw too much force. All you need to do is loosen the nut, pull off the arm, rotate it and push it back down, then tighten the nut.
You can stop your wipers at the top of their travel by turning off the car ( gotta time it just right, though) then you can usually move the wipers into the position they should be in.
Its a very easy fix. Don't fret.
2007 S60 2.5T AWD (Daily Driver)
2001 S60 2.4T (Daughter's Car)
2003 S80 2.9 (Son's Car)
1995 850 2.4 (Daughter's Car - sold off)
2005 S40 2.4i (Bought new - since sold)
1986 740GLE 2.3(First Volvo - sold off)
randalls350
I will try that, thank you for the information! I appreciate it. I will let you know how it goes.
