Replacing the heated 2016 S60 windshield with a non-heated windshield?
eryksd
Year and Model: 2016 S60
Has thanked: 1 time
Post by eryksd »
I live in southern california, so I never use the heated windshield (the wires in the windshield also block visibility in a way, would be better visibility without them).
Also, the non-heated aftermarket windshield is $400 cheaper than the heated version.
I've heard though that replacing it with an aftermarket non-heated windshield could make the car turn on maintenance lights, not sure how big of a deal it would be.
Are there any large downsides to replacing the S60 heated windshield with an aftermarket non-heated windshield?
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
There will be a fault code when codes for the entire car are read out but otherwise no ill effects. I bet a resistor, even a bulb in a two wire socket hidden above headliner would stop the fault code. The monitoring module applies a minuscule current and detects continuity with an intact windshield, a light bulb would supply that continuity. If you turn on the windshield heat you may still get a code as I'm unsure if the windshield heat is a relay controlled or if that is a transistor circuit.
