vacuum leak- 81-245 Topic is solved
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
arete
vacuum leak- 81-245
Post by arete »
Is there any other possibility, other than a hose, for a vacuum leak to occur. It idles @ about 35mph. I have checked all hoses and can detect no leak. I am thinking maybe a gasket or diaphram somewhere that has a hole in it- any suggestions. Car runs fine over 40mph but is a problem in stop & go traffic. Hard on brakes. Car does tend to heat up faster.
Da Towd
Year and Model:
Post by Da Towd »
Have you checked your brake vacuum hose?
we had a crack in the hose close to the motor
good luck
hank
arete
Post by arete »
When I disconnected the low-idle unit, (the one that looks like it might be the ER valve) it runs fine. So now I am focusing on an electrical problem somewhere-tracing out possible grounding issues.
