Splitting hairs at that point. Heat in an enclosed system meaning under the hood needs to go somewhere if it is not absorbed into the Cone Filter or Stock Air Box will go into another component under the hood unless removed outside. That little bit of temp difference is negligible unless the air temp reaches a certain point that it affects the fuel and air mixture in the combustion chamber. The intercooler brings the temp down but if you think about it it is also delivering it right back into the engine compartment. It is a loosing battle in that you need air movement under the hood but it is hot air from the radiator, intercooler and condensor from the AC.RobTarD wrote:I'm now thinking about putting the stock airbox back in. These engines generate a lot of heat and the cone filter is hot to the touch after driving for a while, which isn't good.
I don't think the stock airbox is very restrictive to begin with.
Has anyone heard of using spray-on radiant barrier to cover the airbox and inlet tube?
PS I would stick with Stock Box as the Plastic should have a lower Specific Heat than the Metal and absorb less heat.
