bad valve?
bobbobsley
- Year and Model: 2001 s40
bad valve?
sorry for bad grammar im at work and have to type fast, car started Idling really rough So took it to a mechanic It pulled up 19 codes, he said it shouldnt be running with that amount so he reset it and the first code that came up was cam shaft so the tried replacing that but that wasnt the problem, so he put my camshaft back on and found that timing was off really bad an said the belt was shredded so he replaced the belt the water pump and the ignition coils and spark plugs for $416.00 the car is still running badly like when i took it in he said it bent a valve and it would cost about $650 to fix i looked around on the internet researching valves and I saw one test where you could put paper on your exhaust and its pulling and blowing the paper back and forth and popping it I want on know if this is the valve or is it safe to drive it like this and could their be other problems, could he have actually saw that the valve was bent when changing the timing belt or is he just guessing from how its acting and the code now is for valve 2 it is a 2001 volvo s40 with 129000 miles this was first time the timing belt was changed
- MoVolvos
- Has thanked: 312 times
- Been thanked: 524 times
I would get a second opinion and never go back to the first seeing you have drop $400 dollars to no avail.
