850T with 2-3-1 code
Pauly
Year and Model:
Post by Pauly »
I still get code 2-3-1 in socket A2, after recently relacing the front O2 sensor and throttle position sensor because of some other codes I had. The car runs fine. What's causing this "Long term fuel trim part load at upper or lower limit" fault?
White850Turbo
Year and Model:
Post by White850Turbo »
Quite possibly a vacuum leak. Carefully inspect all of the vacuum lines in the engine bay for leaks. One of the most common spots for leaks is the vacuum elbow on the passenger side of the intake manifold; kinda tough to get to.
-Sean
1995 850 Turbo (Extensively Modded)
1998 S70 T5 (Almost Stock)
