Help with strange noise Volvo S80 2.5T
garortca
Year and Model: S80 2.5T 2007
Post by garortca »
Two days ago begans a strange sound. It appears only when engine is hot. It is like a whistling and it comes from the rolling part where the belts are placed and from the upper part of the engine. When i put engine off I can hear someting like a coffee grinder until it stopps completely. Please help me if anybody can know what is happening.
Reason: Added YouTube video inline
dcarlson12
Year and Model: 1997 850 T5
Post by dcarlson12 »
sounds like a bearing failing in one of the items powered by the serpentine belt??
garortca
Post by garortca »
Thank you dcarlson12 but if it is a bearing why beguns the sound only when engine is hot after 5-7 minutes ? I think it is too much time if a bearing is failing. Otherwise it sounds like a whistle, high pressure air or a valve that is failing anywhere at the upper part of the engine.
When I put off the engine I can hear clearly that anything that is rotating with a really high speed stopps (coffee grinder sound).
jimmy57
Been thanked: 320 times
Post by jimmy57 »
pull out the dipstick and see if it stops.
If so, there is a problem with crankcase vent system. There is a check valve on the turbo with a hose leading to it. The check valve may be stuck. The intake manifold gasket has a check valve adjacent to each intake port. One or more of those could be clogged or stuck open.
Dirtbag454
Year and Model: S-80 2000, C70 2004
Post by Dirtbag454 »
Did you ever find the cause? I listened to the audio on the vid, and I'd stake my reputation as a Bullsh**tter that it is a serpentine idler. You also might want to check the alternator. They make odd noises like that when the bearings are leaving. One quick test I have used on domestic engines is to unplug the alternator. When you de-energize it, the load on the bearings reduces dramatically, and if that is the problem, there will be a noticeable change in the sound. I qualify this last bit of advice because you never know how a Volvo will react to unusual electrical inputs (or lack of). I had an alternator go away on an 850, and take the instrument cluster with it. Get a mechanics stethoscope and listen to various locations on the engine. The noise will reveal it's source. Poke that alternator.
'04 C70 Ragtop (103K)
'00 S80 T-6 (donated @ 140K)
'95 850 (traded @ 120k)
'83 240DL (crashed @ 303k)
And then there's the '70 240Z and the '58 Chevy Apache, not to mention the motorcycles...
2013 BMW K1600GTL
