A breath of transmission fluid...
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Been thanked: 115 times
Post by xHeart »
This morning on my way to work I turned the vent selector knob to face position. And then adjusted the vent to pull in some fresh air. After each stop, as I accelerate, it draws in transmission fluid odor. I am on 2nd D&F.
If I close the vent the odor goes away. Where to look, what to seal? TIA.
Sean-E-Boy
Year and Model: 1995 850 2.3T Wagon
Post by Sean-E-Boy »
Possibly overfilled?
When I first got my 850 and took a few road trips there often was that strong odor of burning transmission fluid, especially after climbing a hill with my foot into the throttle. When checking the fluid afterwards it came up real high on the dipstick.
Just a thought.
Sean
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
The O-ring seal on the dipstick deteriorated on mine and let the dipstick pop out.
'98 S70 T5
2016 Chevy Cruze Premier
JordanW
Year and Model: 96 850R
Post by JordanW »
I'd check for obvious transmission fluid leaks first. Trans oil cooler lines, dipstick tube, axle seals, are all good places to start.
If you do not see anyt obvious trans fluid leaks, the A/C refridgerant oil can smell similar to trans fluid - indicating the evaporator core is leaking; which may be likely if it has never been replaced. I'm not saying your evaporator is leaking, just something to consider as you check things out.
Good Luck
96 850R = ARD Green m4.4, rip, Kilen's, C70vert subframe, S60R exhaust manifold, NA TB with 960 plate, SNAAB J pipe, MSD coil.
