Windshield Scratches from wipers
Ben850
Been thanked: 7 times
Post by Ben850 »
I've been searching some other forums as well as google for a reasonably simple, and hopefully inexpensive fix for windshield wiper pattern scratches.
I want to try to get it done without power tools if possible.
So far the best idea I've heard would be a rubbing/polishing compound of some sort, followed by Rain-x Extreme glass cleaner.
Does anyone have a product or method they have found to take care of theese wiper scratches? They are not extremely deep, they just seem to be a result or worn and dirty blades.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
Juan62
Year and Model: S70 T-5M 1998
Post by Juan62 »
Inexpensive: Mecquire's Ultimate rubbing compound is good...Wal-mart just under $9.00
Acetone: Autozone under $7.00 (for glass only) no plastic, or paint.
There is a product (forgot the name) that used on my glass top surface stove from Lowes (white bottle) that removes pot stains/spills that were burnt on the outer edges of the glass....this stuff works the best for all glass surfaces, but over $10.00
98 S70 T5-M Brick for life
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Unless the scratch(es) are very light, you can forget about it.
NOTHING really works, scratched glass is scratched glass...period
Ben850
Post by Ben850 »
Juan62 wrote:Inexpensive: Mecquire's Ultimate rubbing compound is good...Wal-mart just under $9.00
Thanks, I'll look for the Mcguires. I do have acetone which I use to get glue and paint overspray off. I assume that would be for cleanup and/or pre-clean.
Thanks again, the scratches are minor and I'm pretty sure a compound will at least help.
ruprecht27
Year and Model: 1972 145S
Post by ruprecht27 »
Regarding bad scratches in car glass and windshield wiper scratches, which aren't always as bad depending on how long they ran without rubber, apparently something works according to this video!
[YouTube][/YouTube] didnt work...
2008 Lamborghini Scratched Windshield Completely Resurfaced
Ben850
Post by Ben850 »
I wanted to thank everyone for the input. I did see this video before I made the original inquiry, hence my including "without power tools".
What eventually happened was, I tried the Mcquires solution. It simply is not possible by hand. Maybe with a small buffer like the one used in the video.
Shortly after that attempt, the car was in an accident that deployed the airbags. A replacement windshield was now needed. I pulled one from the junk yard, but noticed after cleaning it up at home, it was no better than the one I was trying to clear up in the first place.
In the end, I decided to pay the extra $70. for new glass. They were going to charge $150.00 to come and install the salvage piece.
Sometimes it is worth it to be sure things are as they should be.
A clear outlook.
A clear outlook.
New windshield view.jpg (69.3 KiB) Viewed 3310 times
