98 V90 Turn Signal Intermittent
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
CBV90Owner
Year and Model: V90, 1998
Post by CBV90Owner »
My V90 turn signal only works intermittently. I found several places that sell replacement switches, however, I could not find a schematic (or installation instructions) and I'm not sure whether this is a job for a do-it-yourself backyard mechanic or if it really needs to be done by a pro. Any documentation/advice is appreciated.
jimmy57
Been thanked: 320 times
Post by jimmy57 »
Both sides refuse to flash or which side?
No flash or is it fast flashing?
Do the emergency (hazard) flashers work?
If it is both sides then turn the hazard switch on and off several times and see if that has any effect.
CBV90Owner
Jimmy 57 - Yes, both sides flash intermittently (sometimes they don't work, sometimes they do), but they're not fast flashing. Thanks for the tip, I'll try flipping the hazard switch.
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
If it is anything like my 1988 760 which uses the same hazard switch as the 92-94 960 the flasher relay is part of the hazard switch. My turn signals would work intermittently at times until they completely quit. I replaced the hazard switch and never had any more issues.
1988 Volvo 760 Turbo Wagon
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
If they just don't work outright (rather than sticking on), look to your ignition switch. Next time they act up, jiggle your key a bit and see if they function again.
The 960/V90/S70/850 all use the same ignition switch, and it stops to spring back or make good contact after many years of use. Replace the electrical portion and you should be good to go, if this is indeed what's causing your problem.
'98 S70 T5
2016 Chevy Cruze Premier
