I recently repaired the exterior door handle which had suffered failure due to the disintegration of the internal linkage piece.
Upon completing the repair I closed the door to do a final check that I had done the repair correctly.
The door would not open from the outside. It would not open from the inside either.
Luckily, I had not replaced the interior door panel.
How can I open the door. I have tried to figure out the latch mechanism. So far, no luck.
Any advice that will lead to a solution will make me a very happy fellow. Thanks.
