Rear passenger door stuck closed.
rguzz
Year and Model: 1996 850 turbo
Been thanked: 25 times
Post by rguzz »
96 855 rear door wont open from inside or out and lock appears to be in the closed position. Searched for the fix but found only piecemeal info and I know this has been discussed a few times, don't remember the fix. Remind me, thanks.
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
rguzz wrote: 14 Apr 2024, 06:07 96 855 rear door wont open from inside or out and lock appears to be in the closed position. Searched for the fix but found only piecemeal info and I know this has been discussed a few times, don't remember the fix. Remind me, thanks.
Internal latch failure, there seems to only be The Final Solution:
With luck the plastic standoff pedestals will detach themselves from the back of the door card - if they aren't already. Apply patience and the panel is usually salvageable. Can't remember if the 850s had a couple of screws in the bottom, but breaking stuff getting access is inevitable.
Much easier on a back door than one of the fronts, since the seat isn't in the way.
foggydogg
Post by foggydogg »
And don't forget to hit the thumb button, helps with the Y/T algorithm. Might get Robert an extra $0.01.
Has thanked: 2207 times
Been thanked: 1852 times
Tailgate or passenger rear door?
Tailgate, Robert DIY did a video on removing the inner panel and unlatching it I recall. I did a quick search but could not find it on YouTube.
There have been a few threads on stuck rear and front doors. Basically it requires removing the inner door panel to allow access to the lock mechanism. It is hard to do without damaging the inner door panel but it can be sone with patience.
rguzz
Post by rguzz »
Thanks. Looks like a somewhat miserable undertaking, unfortunately. Maybe I should find a replacement salvage door panel before I start. Maybe just the bench has to come out. I think Robert has the definitive steps on removal and repair of the failed mechanism in one of his videos not sure yet how to tackle that.
454cid
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
I wonder if a slim-jim/unlocking tools would work? I think I'd see what Amazon or ebay had before breaking anything.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
rguzz
Post by rguzz »
The door panel should come off okay and Robert's videos do outline the repair needed pretty clearly so time to give it a whirl. The little grommets that disintegrate and hold the rod in place are available through FCP. Looks like re-configuring the rod is also an option. Spring is here, my annual Volvo time of they year to catch up on nuisance repairs so no excuses.
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
rguzz wrote: 14 Apr 2024, 18:47 The door panel should come off okay and Robert's videos do outline the repair needed pretty clearly so time to give it a whirl. The little grommets that disintegrate and hold the rod in place are available through FCP. Looks like re-configuring the rod is also an option. Spring is here, my annual Volvo time of they year to catch up on nuisance repairs so no excuses.
My 2002 V70 XC hatch won't lock or unlock sometimes. I was thinking of adding a pull lever if there are provisions in the lock for hooking something. However, it might be easier to unlock with an opening?
Looks like you can cut an opening and cover it with something later? If there is room on the inside you can get a shallow low voltage old works box. There are various cover colors to choices from to match the interior.
https://www.lowes.com/pd/CANTEX-1-Gang- ... 5001724769
https://www.lowes.com/pd/Eaton-1-Gang-B ... 1002095486
tailgate will not unlock and open
viewtopic.php?t=18360
