XC70 Recharge A/C - Need Intake Adapter-R134A
pcrawford
Year and Model: 2003 XC70
Post by pcrawford »
the 2003 XC70 A/C refill/intake port is a different connector size than the universal recharge kit coupling (diameter smaller-wont fit over nipple). the recharge kit came w. only 1 compression fit adapter (plastic). probably meant for american cars. I bought it at advance auto parts-EZChill brand. It works on my daughters 2001 Toyota GT. Sorry for bad typing. Had L/Shoulder surgery 3 days ago. Can only type with one hand. Where can I find one? Thx Phil Cell:239-398-3020
jimmy57
Been thanked: 320 times
Post by jimmy57 »
You may not be using the right port.
The one you should be using is ion the frame rail directly in front of timing belt cover. You will hve to lift the coolant hose from the fender mounted tank to see it. The two fitting sizes are done to prevent using the wrong one where the pressure can explode the refrigerant can.
Bigblue
Year and Model: 2001 XC70, 1991 740
Post by Bigblue »
The fitting protruding through the hood striker plate is high pressure port and is not the one you want to connect to...As pointed out, the low pressure port is down low near the serpentine belt...That's the one you want to connect to for a recharge...They deliberately make them different sizes so that you cannot make a mistake and connect the can to the high pressure side, which can have close to 300psi, depending on certain conditions...That can exolode the can and injure someone...
