I need to do a little engine compartment cleanup and would like to see what you've done with your sparkplug cover. The "Volvo 20 Valve" writing looks bad on my new-to-me 850T, so it's time to freshen it up.
1995 Volvo 850 Turbo, 129k & working on Stage 0
2000 Toyota 4Runner 4WD 5-speed, TRD Supercharged
Post your painted spark plug covers
- RobTheModd
- Year and Model: 98 S70T5M
- Has thanked: 5 times
- Been thanked: 7 times
My engine at one point seems to have gone thru a different color combo everytime I opened the hood.
I have over 20 different engine paint set ups but these are a couple of the ones I liked more.
You can do any of this with engine paint found at a autozone or advance auto. Spray can works fine.
Just make sure you tape some stuff off if you start spraying the engine.
and light coats on the spark plug cover.
Wash the plug cover VERY well with soap and water, lots of rinsing and some degrease to remove any oils that have soaked into it, or it will come out looking bad.
Currently it sits waiting to be polished, I put the plug cover back on, but I havent had time to go back thru with different grits of sand paper to shine it up.
vjaneczko
- Year and Model: 2006 S60R
- Been thanked: 6 times
Rob, did you tape off the intake & head to paint them or were they out of the car when painted?
Here's my cover. I've wanted to paint the words in white but I just haven't gotten around to it - yet
1997 855 GLT - R.I.P.
2006 S60R - For ME!
2006 S60R - For ME!
- RobTheModd
Nope engine and everything was still in the car.
vjaneczko
I PM'd someone that had a beautiful paint job on the raised letters (even on the oil cap!) and he said he used a small paintbrush and a very steady hand!
2006 S60R - For ME!
2006 S60R - For ME!
B5234T3
- Year and Model: 1998 C70 T5 Coupe
I took some pics of mine while I was doing the job, thinking one day when I get off my a$$ and join the forum it may be helpful to someone
I masked up the lettering with tape, and once painted over, just peeled the tape off. It still didn't look right, so I got a Q-tip dipped in white spirits and stroked it over the raised lettering, removing any remaining wet paint. I did it while the paint was still slightly wet. Worked a treat. The silver lettering in the pics is of the original paint. I Preferred it like that vs just painting the entire panel.
1995 Volvo 850 NA Sedan, Auto 4sp (Regent Red) - 430,000 kms!
1996 Volvo 850 R Sedan, Auto 4sp (Black Stone) - 240,000 kms
1998 Volvo C70 T5 Coupe, Manual 5sp (Saffron Gold) - 130,000 kms
2000 Volvo V70XC P2, Auto 5sp (Venetian Red) - 260,000 kms
2002 Volvo S60 T5 Sedan, Auto 5sp (Maya Gold) - 170,000 kms
vjaneczko
Man, that is a sweet job!
2006 S60R - For ME!
2006 S60R - For ME!
B5234T3
Thanks! I should have also mentioned that you can achieve a similar result by using a paint pen. They sell them at the local hardware store in all different colors. It's good for if your not actually going to paint the cover and want to touch up the silver highlights/change the color.
- BobbyC777
- Year and Model: V70 2.5T, 2004
- Has thanked: 15 times
- Been thanked: 5 times
Nice valve cover pix !
When I was changing plugs on my V70 (2004) I noticed that the 8 T30 bolt heads were a little corroded and I'd like to clean them up. Someone suggested phosphoric acid (naval jelly) but I don't think that would offer future protection.
Any tips or pictures welcome. Thanks.
Bob
p.s. one might think that I had everything else in my life squared away if I'm worrying about this stuff - NOT SO !
Bob
