Tire rotation: front-to-back? Side-to-side?
daedalus
Year and Model: 2010 XC70 T6
Post by daedalus »
Well, after some minor issues with the AWD system, I removed the rear drive shaft and have noticed that it is quieter and is getting slightly better mpg. Anyways, my question is: Now that my car is now a FWD, I can rotate the tires in the conventional way, correct?
Reason: Was "My 2000 V70 XC has been neutered..." It took a path into tire rotation protocol, thus the rename.
2010 XC70 T6...140k
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 93 times
Been thanked: 146 times
Post by BEJinFbk »
Conventional for any modern car
with radials should be front to back.
Am I missing something here?
And keep in mind that the mileage
and noise may have been related to
poor CV/U-joint condition in the shaft.
Probably worth repairing before winter:
http://coloradodriveshaft.com/
Ask for Dave - He'll hook you up!
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Front to back IS the "conventional way.
Never cross rotate
You don't have 45 year old biased ply tires
jimmy57
Been thanked: 320 times
Post by jimmy57 »
Why do you say that JRL? Michelin and most others have back to front and cross rotate to back as a recommended method. For some they show it as an alternate way to do it but I just looked at Michelin website and they show it as the primary way to do it.
It is very commonly done when there is any scalloped wear pattern.
45 year old radials may have had this as an issue but belt stability has been fixed.
Tires with pre-existing issues (like tires that are known to have been run very low for a long time) may still have problems from this but those tires may have had problems anyway.
I haven't had a cross rotate issue in long time and that is the way I do it unless i have other reasons not to.
Directional tires are an exception
JRL
Post by JRL »
then knock yourself out
daedalus
Post by daedalus »
I second Jimmy's assessment. It was my understanding that cross rotating was the standard way to do it, as shown below in example B. However, my understanding aside, what is the consensus here on proper FWD tire rotation? What does everyone else do? Jim, are you saying that the tires should stay on the same side of the car permanently?
2010 XC70 T6...140k
sliptones629
Year and Model: 1994 850 wagon
Post by sliptones629 »
I think you need to be very careful as a lot of tires today have directional tread patterns. So you can't cross front/rear, your tire would be going the wrong direction down the road.
jimmy57
Post by jimmy57 »
After I knocked myself out I looked at every major tire manufacturer and they all (Continental does not have a chart I could find) show cross rotation as the recommendation.
Again as listed in my post above, directional tires are not included and go front to back only to preserve the tread pattern orientation that makes them directional. The limited number of cars with different size tires front to rear also are excepted (these tires usually last less than 15K anyway..).
daedalus
Post by daedalus »
+1 on the knocked yourself out....too funny!!
2010 XC70 T6...140k
Oddbob
Year and Model: 1995 854 Turbo
Post by Oddbob »
At the shop where I work we do front to back rotations. I'm not entirely sure why, but I'm certain we do it simply because its easier to do one rotation pattern for all cars (for directional and non-directional tires).
The Good - 1995 850 Turbo
The Eh... - 2004 Ford Focus
The Dead - 1996 850 GLT - The bane of the Grand Cherokee..
