add MBC to 850t or not
How to go faster, stop quicker, and turn harder. Chips, exhaust, larger turbos, bigger/slotted/drilled rotors, high performance brake pads, manual boost controllers, performance shocks/struts/springs, airbox mods and more! Also discussion on HID and Xenon lights, aftermarket foglights and other exterior lighting.
Locked
phils94850
Year and Model: 2009 s60 turbo
Post by phils94850 »
i added a MBC to my other 94 850t and it really woke her up. The 850t i have now is still all stock basically. I turned the wastgate rod in about two turns to help with take off.
Ive read mixed reviews on adding a MBC. My boost gauge ( factory ) goes just a bit into the white. If i add a MBC and get a aftermarket boost gauge, whats a safe boost level to turn it up too ? Im planning on getting a tune soon also.
1996 Platinum Edition
9394volvo850s
Year and Model: 93 850 5spd 94 850T5
Post by 9394volvo850s »
I wouldnt go over 12PSI. make sure you have a good boost gauge before doing it. you dont need a mbc. I just used the wastegate rod.
93 850 5spd 320k (the daily)
94 850 T5 190K (race car)
95 T-5R wagon yellow (summer wag)
90 745 5spd 295k (winter wag)
67 122 2 door 4spd 69k :))
z31jaime
Year and Model: 1995 850 turbo wagon
Post by z31jaime »
+1. im running abour 10-11psi. remember @ 14ish you will hit fuel cut with the stock ecu. so @ about 10-12psi your safe and still getting some extra power.
phils94850
ok, thanks guys, ill give it a shot :)
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2656 times
Been thanked: 1248 times
Post by matthew1 »
I'm running 15psi with stock internals. See this manual boost controller topic for more info.
Also -> Amazon link
Locked
