When I was driving my 02 S60 2.4T FWD on the highway tonight. I set the speed by cruise control. Speed was around 74 mph.
Then I heard loud noise from front right side. I thought it was my front tire got flat so I pulled my car over to the right shoulder and checked it.
The tires looked good. Then I tried to move my car but it just couldn't move at all. I switch from P to D, nothing happened. To L, 3, 4 and R, still nothing. Then I tried to switch to P and heard some noise. The car is dead. It was still power on but it just couldn't move at all. I tried to push the pedal, the engine sounded normal and the RPM looked normal.
Now I am afraid that my transmission got failed but I would like to ask, if there is anything else could lead a Volvo can't move at all?
Thank you!
Transmission Failure?
dongwenxuan
- Year and Model: S60, 2002
DGM
- Year and Model: V70 2.4i 2005
- Been thanked: 3 times
A joint in the front right axle may have snapped.
http://www.fcpeuro.com/products/volvo-c ... pi-80-4584
It is a possible cause.
V70 2005 2.4i 195,000km, sold
S70 1998 T5 355,000km, sold
960 1994 80,000km, sold
760 1990 Turbo 265,000km, sold
deadmerelda
- Year and Model: 2003 V70 2.4T
I would 2nd this. I don't know if it happens on these cars but I have seen an axle simply pop out of the trans on other cars. They just have a snap ring sort of thing on the end that keeps it locked inside the tranny. With any luck it's just that, otherwise time for a new half shaft.
dongwenxuan
If this will cause the car fully stopped and not be able to move at all?DGM wrote:A joint in the front right axle may have snapped.
I replaced both axles 6 months ago and this is the one I bought last time.
deadmerelda
Absolutely yes.
dongwenxuan
I found the video when my car was failing.DGM wrote:A joint in the front right axle may have snapped.
Please listen to the noise.
DGM
I can't ear much on the video. Have the car inspected by a good mechanic on a hoist. It should be relatively easy to determine the source of the problem.
You should get free replacement, with only 6 months on it...including labor, if the shop did it...Or, if the axle is no longer warranted, try to squeeze for free labor...and post the source of the axle, and if they stand behind it, please! My local indie would do it again free, whether the supplier warranted the axle or not, because its bee so recent.
dongwenxuan
Update: the passenger side axle pop out so that the car lost power. my mechanic just tight it up, it could be driven now. But if it is safe to drive this car?
