A/C water leak inside of car
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Kushballz
Year and Model:
Post by Kushballz »
Hello All,
I have been getting water from my air conditioning leaking inside of my car on the passenger side of the car's center console. It's not like a little drip here and there, rather tablespoons and tablespoons of water. I removed the covers and tried to find out where the water was coming from, but I couldn't find the source of it. It does drain outside underneath of the car, but it seems like maybe there's a drain tube that's clogged if one exists. It only spills when I make sharp left turns, and it will go all over the floor mat, and some of the carpet around the center console. When I removed the cover on the side of the center console, the only water i could see was near the air ducts that lead to the rear under seat cooling. I did look at the condenser inside, and everything around that area is dry. Please help me out on this one... It has got me stumped, and I would really appreciate any help on this one. Thanks in advance
1985 Volvo 240
4-cyl B230-F
RWD
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
There should be at least one, usually two, drain tubes underneath the heater air intake. It, or they, should be visible coming out near the bottom of the firewall, usually down behind the engine.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
