door panel clips
travis873o
- Year and Model: 1990 740T
door panel clips
anyone know of any online vendors that sell door panel clips and speaker grill clips for our 740s? The junkyard has a bunch but they always break when I try to remove them.
lummert
- Year and Model: 760 1988
- Been thanked: 26 times
Which clips do you need? I have successfully removed several of them. Try using a screwdriver to shove one side of the tab from the back side toward the center of the tab. After one side releases, push the other tab with the screwdriver while making sure that the first tab doesn't slip back into the hole. The clips should be the same for 89-92 740, 89-90 760, 91-95 940 and 92-96 960.
1988 Volvo 760 Turbo Wagon
travis873o
the ones that go across the bottom the the white clips attach to and the ones the speaker grills attach to.
Kirby J
- Year and Model: 99 v70, 93 940
Waltrip Volvo in Franklin TN sells them for about 1.50 each. That sounds high, but you only need three per door, and then a couple for the speakers. So for around 25 bucks you can fix all four doors and not worry about it any more.
Kirby J
Kirby J
