Hi All
I have a 2001 V70, 98,000. I just got a code P1618, Fault on Lead Between AW-50-52, Motroic 4.3. I had the code cleared, it came back within 100 miles. The Car runs find. Cannot detect any difference. Anyone have this problem. Thanks Geomart.
Transmission code P1618
DGM
- Year and Model: V70 2.4i 2005
- Been thanked: 3 times
This code is generic and difficult to erase by backyard mechanic as us. You need a scanner that can access both the TCM and ECM. Most scanners only erase codes in the ECM and it come back.
You can "google it" for more information (Volvo P1618).
Find this thread were a specialist explains this condition.
http://www.justanswer.com/volvo/59tfi-v ... where.html
Ideally you should have it scanned by Vida-Dice or a scanner that can interpret Volvo propriatory codes. It can be only a "glitch" or something associated with the transmission.
V70 2005 2.4i 195,000km, sold
S70 1998 T5 355,000km, sold
960 1994 80,000km, sold
760 1990 Turbo 265,000km, sold
Thanks for the Help. It had me worried. I just had the Throttle Module replaced a couple of weeks ago. I was wondering if there was some relation. Maybe the Mechcanic just losened something. And low and behold, I got the DRL's turned off. After being told several times it could not be done. While it was in last time, asked again, $30.00 later, done. Thanks Geomart
V70 2001 97,000
850 1997 115,000
S60 1998 166,000
850 1998 172,000 Sold
240 1983 189,000 Sold
1800 1971 148,000 Sold
V70 2001 97,000
850 1997 115,000
S60 1998 166,000
Got car back from Dealer about the Transmission Code P1618. I'm being told the Torque Converter Switch in the Valve Body is Bad. They would not clear the codes in the TCM, will discontecting the Battery remove them?
Been reading all the bad things on the Forum about these Transmissions. I'm woundering wheather to Rebuild the Valve Body only or the hole thing. Other than the warning lights being on, there is no problems, no hard shifting or other signs somethings wrong.
- 932 Views
Last post by dandanboi25
- 761 Views
Last post by Matty Moo
