Hi, I have a volvo s60 2002 heavy oil car. The ABS control unit has failed and attempts to repair have been unsuccessful. The software will not transfer over to a refurbished unit due to corrupt coding. Can anyone answer the following as buying and fitting from a volvo dealership is vastly expensive.
1. If I buy a new unit will it require to be re-programed or will it work as there are no previous stored codes. I am based in Glasgow, UK does anyone know of an independant garage should this be the case.
2. I have downloaded the VADIS software, if I bought a compatible tool for this software could I reprogram the unit myself. If so can you recommend the correct tool.
Any help or advice would be greatly appreciated, thanks in advance, Raymond
ABS/BCM CONTROL UNIT VOLVO S60 2002 D5
DGM
- Year and Model: V70 2.4i 2005
- Been thanked: 3 times
1- A new unit will need to be programmed by a software download from Volvo. You can contact Xemodex. They repair and refurbish these modules.1thomson wrote: 1. If I buy a new unit will it require to be re-programed or will it work as there are no previous stored codes. I am based in Glasgow, UK does anyone know of an independant garage should this be the case.
http://xemodex.com/technologyimproved/u ... -for-volvo
Find this long thread about ABS module repair. You will find reference to a few indendant folks who repair them.
https://www.matthewsvolvosite.com/forums ... &start=336
2- Only shops equipped with Vida-Dice can download software from Volvo. Mainly they are dealers or independant shops who pay subscription fees. If you are equiped with Vida-Dice you won't be able to download software or do software upgrades unless you pay these fees ($$). However Vida-Dice is a valuable tool to diagnose and interpret Volvo propriatory codes.
V70 2005 2.4i 195,000km, sold
S70 1998 T5 355,000km, sold
960 1994 80,000km, sold
760 1990 Turbo 265,000km, sold
