A/C Compressor Pulley Sticking
ksdst1
- Year and Model: 1996 Volvo 850 GLT
Re: A/C Compressor Pulley Sticking
Thanks for the clarification....ordered one and hope to take care of it soon...
Volvo 850 GLT 1996 Auto
ksdst1
Hi all....i received the Gates K060495 belt and would like to install the belt to bypass the a/c compressor. Just to clarify though:
1.Is the compressor power supply to disconnect the one shown in the picture below?
2.The Gates K060495 belt is not double sided but the diagram below of the belt path without a/c looks like it needs double sided. Am I getting this wrong?
3.Also, will disconnecting the compressor affect anything else other than no a/c for my defrost? It doesn't affect the heating system, correct? I'd like this work around to get me to next spring.
Tnx....
Tnx....
- dscn8025.jpg (305.49 KiB) Viewed 1368 times
- belt.gif (42.21 KiB) Viewed 1368 times
- kcodyjr
- Year and Model: 2006 S60 2.5T AWD
- Has thanked: 17 times
- Been thanked: 23 times
1. No, that's the high side pressure sensor. Disconnecting it will make it cycle endlessly. Look down near the compressor, you should see the clutch control wire leading to it. Disconnect that.
2. Although the belt back is against the idler and tensioner, there's nothing being driven by that side of the belt, and it hasn't been an issue. 25K or so miles in with mine.
3. It will only affect your ability to get cold/dry air. Nothing else should be affected.
5 others that came and went
ksdst1
Thanks for the quick reply. Ok, i'll focus on the wires on the compressor. It looked like there was just one wire connector that I could disconnect but I guess one would be enough to kill the circuit. And for the belt, I'm glad to confirm that the picture is the right belt path.
Tnx again!
Tnx again!
- kcodyjr
Yes, that's it. The clutch circuit is grounded through the compressor mounting bracket.ksdst1 wrote: It looked like there was just one wire connector that I could disconnect
Disconnect that, and the clutch will not even try to engage.
Incidentally, short that to positive to force the compressor on during filling.
ksdst1
I forgot to update on this. I was able to use the new belt to bypass the a/c compressor and now am running with no problems. One note..the belt tension-er is always tough to compress using a square socket extended...i forgot that last time i did this i had the coolant fluid reservoir and other parts out first to give me space to use the socket. this time, no. I unbolted the tension-er and compressed it by hand and knew on the ground and remembered the trick to put the long end of a thinner hex key through a whole on the assembly and have it anchor to the other part of the assembly to keep the tension-er compressed to bolt back into place....this way it is easy to get the belt on before removing the hex key to allow the tension-er to expand and work with the belt properly.
Tnx all for the good advise!!
- Year and Model: Many Volvos
- Been thanked: 75 times
On a '98 the same bypass belt should work. The stock '98 belt is 5mm longer but the tensioner should adjust to it. The sooner you get around the compressor the better since it will usually burn the belt in half when the compressor clutch finally locks up.
There are a couple of threads that call out the replacement bearing for the clutch.
For future readers, the '99 and '00 70 series is a completely different belt.
