Looked at a 98 V70 T5M today. Issues inside
obayha
Year and Model: V70 1999 Base
Re: Looked at a 98 V70 T5M today. Issues inside
Post by obayha »
The cam seal could leak the oil onto the exhaust, but most likely it's the PCV system if it hasn't been done in a while. Like said earlier. It pools up around the rear of the motor and then on a hard right turn, it flows over and the smoke begins to flow out the back for a few seconds. Speaking from total experience of course. My cam seal leak looked more like my RMS was leaking.
The compression test should tell a lot.
Now if it has a bad heater core, I would scrap it for sure. I hate plumbing, and hate it worst in cars. :D .
Shane
1998 V70 T5 331,000 :( Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
rmorse
Year and Model: 96 855R
Post by rmorse »
obayha wrote:The cam seal could leak the oil onto the exhaust, but most likely it's the PCV system if it hasn't been done in a while. Like said earlier. It pools up around the rear of the motor and then on a hard right turn, it flows over and the smoke begins to flow out the back for a few seconds. Speaking from total experience of course. My cam seal leak looked more like my RMS was leaking.
Shane
Lol, you need to do a heater core on these cars before you say that.... I can get one done, start to finish, in about 30 minutes. Soooooo easy.
obayha
Post by obayha »
Lol, you need to do a heater core on these cars before you say that.... I can get one done, start to finish, in about 30 minutes. Soooooo easy.[/quote]
I'm fighting one right now. The next one I do will be a lot quicker. My old bones don't bend like they did a FEW years ago.
Mainly stating that these older cars come with problems that spring up after years of ownership that were not thought about.
rmorse
Post by rmorse »
Ooo. Yea, I'm in my mid twenties, so I still bend pretty good! :D
cmblackburn
Year and Model: 1998 S70 T5M
Been thanked: 7 times
Post by cmblackburn »
obayha wrote:Lol, you need to do a heater core on these cars before you say that.... I can get one done, start to finish, in about 30 minutes. Soooooo easy.
Mainly stating that these older cars come with problems that spring up after years of ownership that were not thought about.[/quote]
Pulling back the carpet helps quite a bit! I didn't damage a single fin when I installed it.
Smashed the old one, but that's a different story.
Shane, you were pretty good at smashing that crappy 850 for the air pump that didn't work :P
Give that 855R a good look over, check everything. From what I've heard, R's are the ones that everyone beats on.
1994 855 Turbo, 243k "Honey Badger"
1998 S70 T5M, 287k "The Blue Turd"
2004 S40 2.4i, 197k "Cosmo"
2005 XC90 2.5T AWD, 207k "Apollo 13"
2011 VW Jetta SportWagen TDI 6MT, 93k "Zoe"
obayha
Post by obayha »
Back to the 98V70T5M with issues.
If you have the time and money, it might be worth a low offer. I would still do a compression check.
The T5M sounds like an interesting one.
Shane
