Bad Starter? Battery issues car won't start after sitting
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
lummert
Year and Model: 760 1988
Been thanked: 26 times
Re: Bad Starter? Battery issues car won't start after sittin
Post by lummert »
Four weeks is not a long time for a car to sit.
1988 Volvo 760 Turbo Wagon
rgk
Year and Model: Gray 88 245
Post by rgk »
Explain what happens when you try to start the car. Does your starter rotate as normal, or slow and sluggish?
rgk -- was dickdeadly
Fred760DC
Year and Model: 1990 760 SW
Post by Fred760DC »
Battery. BAttery chargers report "fully charged" when the battery can take no more juice (amps) but a bad cell or two would keep it from turning over, even if the charger gauge says fully charged. Put a voltmeter on it and see if it reads 12Volts min.
2 AMPS PER HOUR OVER NIGHT IS 16 AMPS. Not much in a dead battery. Diehards are like 885cca, so 16 is less than that.
I'm glad you bought a charger, rather than rip off the retailer. Did it have instructions?
Solenoid. If the batery is too low to turn the car over you might still hear a loud click from the solenoid that throw the bendix gear to let the starter motor (electrical) engage the engine's flywheel. The starter is on the engine drivers side all the way to the rear down low. It's cylindrical, and has a whooping big wire leading to it. make sure the connection is tight. (Wiggle it with your hand.) It feeds the solenoid which clicks into place and feeds power to the electrical motor. It also moves a spring loaded gear gear into place between the starter motor and the flywheel because you can't have the starter engaged when the car engine is running. (That's that screeching noise we all hate) If you remember starting the car while it was running you could have fried the solenoid, (which is cheaper than a starter) and the starter won't get juice at all. Stuck solenoids often respond to a sharp rap with a heavy screw driver. Notice the drum the big wire goes into and thump it. While someone turn the key. If it starts don't replace the starter, just the solenoid. (It is ok to bang your head when leaning into a car to rap on a solenoid and it suddenly starts.)
Volvos will not start without oil pressure, which is a good idea, but often overlooked. Check it often and now.
