1990 760 Turbo will not start
Don,t seem to be getting fuel. Replaced inline pump and filter a few months ago. Set for a month or so move to garage to work on brakes. Tried to start was not getting fuel. Replaced in tank pump still not getting fuel. Tank pump runs.Separated line before inline pump no fuel, with tank pump running. Anybody have any ideas?
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
If the in-tank pump is running all the time with no fuel coming through I would suspect either no, or insufficient, fuel or the pump has detached from the sender unit and isn't in the fuel. The other thing that comes to mind is the pipe from the in-tank pump is nipped or obstructed.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
The in tank pump runs then kicks off. took hose at pump off and put in can and fuel came out. still none to in line pump. Car has started a couple times ran for a little bit and died. Is the in tank suppose continue to run.
Sorry just looked at your last post, Most likely a blockage in fuel filter or a crimped line as Bill suggested.
Keep removing sections of fuel line and blow them out with air If you have a fuel filter you can try and run fuel through it backwards to clear it or replace it. If the pump pushes fuel it has to be a block somewhere.
Thanks for the help guys. Think I have that problem solved. Seems I switched the lines in the process of changing the pump out. Really feel like an idiot HA.
Now back to original problem. No brakes pedal goes all the way down. I've pumped till I'm blue in the face and get fluid to all but the front left wheel. Do you think it is the master cylinder or the ABS pump?
- 328 Views
Last post by Richiebuonanotte
- 414 Views
Last post by angeltease
