'88 740 turbo-rough idle/runs good otherwise
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
DG13
Post by DG13 »
I have an'88 740 TURBO. The car doesn't want to idle when cold. Once warm, idles erratic but drives great. At idle if you rev the engine a couple of times, the idle evens out for a short while. I have replaced my intake mainfold gasket, some vacuum lines, cleaned the idle control motor. The plugs are white like the car is running lean. My fuel pumps are both new and I have good fuel pressure. HELP!
roger bakos
Post by roger bakos »
I had the same problem, replace air mass metor, idles great,
though I have a high rpm problem, that's another story thou
[email protected]
Derwin
Post by Derwin »
roger bakos wrote:I had the same problem, replace air mass metor, idles great,
[email protected]
What is the High RPM Problem?
[email protected]
