Brake Lights - Rear stopped working
Lance L
Year and Model: 2001 s80
Post by Lance L »
Light in center light works, rears do not. I have checked front and back fuses. Swapped and replaced relay with new on REM. Swapped the shunts. Bulbs are new.
Relay seems to click on braking. What am I missing. Brake light failure light always lights when brake engaged - sensor?
Thanks Lance
jimmy57
Been thanked: 320 times
Post by jimmy57 »
Since you have done so many things I would do a battery reset (pull off ground cable and touch to the pos cable/post for 10 seconds then put it back on). After that lock and unlock with remote.
You may have fixed it but the REM may not have reset.
Lance L
Post by Lance L »
Looking online for the ground. Would this be in by the rear battery?, or in hood by the jumper post?
And as you instructed, this ground wire is contacted to the positive post for 10 seconds?
thanks for your reply,
Lance
Lance L
Post by Lance L »
Is the negatice connection also the ground? I might be stupid here.
Lance L
Post by Lance L »
Ok did perform reset and remote close/open. No luck. Any other options, hate to take it to an auto electric place, let alone dealer,thanks again to all.
av8rdude007
Post by av8rdude007 »
Same year, same model, same problem. Local shop quoted $900 to code and replace the REM. I'm thinking it's got to be repairable, right?
