Light in center light works, rears do not. I have checked front and back fuses. Swapped and replaced relay with new on REM. Swapped the shunts. Bulbs are new.
Relay seems to click on braking. What am I missing. Brake light failure light always lights when brake engaged - sensor?
Thanks Lance
Brake Lights - Rear stopped working
jimmy57
- Been thanked: 320 times
Since you have done so many things I would do a battery reset (pull off ground cable and touch to the pos cable/post for 10 seconds then put it back on). After that lock and unlock with remote.
You may have fixed it but the REM may not have reset.
Looking online for the ground. Would this be in by the rear battery?, or in hood by the jumper post?
And as you instructed, this ground wire is contacted to the positive post for 10 seconds?
thanks for your reply,
Lance
Lance
av8rdude007
- Year and Model: 2001 s80
Same year, same model, same problem. Local shop quoted $900 to code and replace the REM. I'm thinking it's got to be repairable, right?
- 14 Replies
- 2759 Views
Last post by crlande
- 1970 Views
Last post by Sixthandredline
