XC90 T6 has an engine oil pan gasket?
Year and Model: XC90 0406, 2012 C70
Post by 007 »
Hi All,
Does the XC90 T6 has an engine oil pan gasket? as same as some other vehicle brands?. I am having an engine oil leak, and I can see the oil near the timing belt and pulley.
Thanks for reading and for the help!
Reason: Edited title for clarity.
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
The white block engines use Volvo factory sealer between mating surfaces. All that's required are clean surfaces and Volvo's anaerobic sealer.
I'll post the part number as soon as I get back home.
The sealer part number is 1161059. there are a number of other sealers that will substitute but I do believe Volvo's product is very good.
Cam seals are more likely the culprits of your leaks
007
Post by 007 »
Hi, thanks for taking time to read my post...
I am ordering the Oil pump gasket kit #274260 and 2 gaskets #9458309. I will come back when replaced both of them. By the way, do you know the procedure to replace these parts?
Thanks again.
