Hi All,
Does the XC90 T6 has an engine oil pan gasket? as same as some other vehicle brands?. I am having an engine oil leak, and I can see the oil near the timing belt and pulley.
Thanks for reading and for the help!
Reason: Edited title for clarity.
precopster
- Year and Model: Lots
- Been thanked: 128 times
The white block engines use Volvo factory sealer between mating surfaces. All that's required are clean surfaces and Volvo's anaerobic sealer.
I'll post the part number as soon as I get back home.
precopster
The sealer part number is 1161059. there are a number of other sealers that will substitute but I do believe Volvo's product is very good.
Cam seals are more likely the culprits of your leaks
Hi, thanks for taking time to read my post...
I am ordering the Oil pump gasket kit #274260 and 2 gaskets #9458309. I will come back when replaced both of them. By the way, do you know the procedure to replace these parts?
Thanks again.
Thanks again.
