B230F Head Gasket Replacement
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
e777
Year and Model: 1990 740
Has thanked: 11 times
Post by e777 »
I am about to put a used head from my parts car on a recently acquired '93 940 wagon that had a warped head. This is my first time doing this, by the way.
Two questions:
1. Is a gasket sealant generally used with head gaskets? I know sealants are used with water pump and other gaskets, but I was unsure as to the head gasket.
2. Is it advisable to use a thread lock compound on the head bolts?
Thanks!
--Eric
93 940 214k
91 240 235k
90 740 273k
86 740 276k
Wagons:
93 940
91 240
90 740
86 740
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Eric,
Before fitting the 'new' head it may pay to have it checked for warping. My friendly Volvo tech insists that this is necessary on any head removed from a Volvo. You can do it yourself using a straight edge. Also check the head height to see if it has been skimmed at any time. Specs are in the attached:
B230F cylinder head measurements.pdf
(38.33 KiB) Downloaded 638 times
The head gasket should be put in place with the mating faces clean and dry - no sealant.
The head bolts must be clean and lightly oiled - no thread lock compound.
Good luck with this job.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
e777
Post by e777 »
Thanks very much, Bill.
I particularly appreciate you mentioning the need to check the replacement head for warping, something I would have otherwise skipped.
--Eric
Wagons:
93 940
91 240
90 740
86 740
e777
Post by e777 »
So, I am in the midst of surface prep to fit the new cylinder head.
I am having a heck of a time getting the block surface clean. It is one thing to scrape the old gasket off, but quite another thing to get it squeaky clean. I refer to the carbon deposits, which, after repeated soakings with surface primer (aka brake cleaner) and scrapings, refuse to come off. The manual calls for the use of a wooden scraper, but this can't get the toughest spots clean no matter how much you scrape. Any suggestions?
On Youtube I saw a man who appeared to be an experienced mechanic use sand paper to clean the block surface, which seemed rather extreme.!?!
By the way, don't let this happen to you: As I was moving the cylinder head around on my work bench, at some point the mating surface rubbed on a tool or bolt, leaving it slightly gouged in the worst possible place - right on the edge of where the recessed valve area is. Now I will need to get it resurfaced. Lesson learned.
Thanks.
Wagons:
93 940
91 240
90 740
86 740
