These are recent Youtube videos of 99 S70GLT coolant leak diagnosis and
head replacement.
I thought they were well done and worth the time. He has 3 videos so far,
20 min each, and there should be a 4th for the head re-install.
Videos of 99 S70GLT head replacement
- Year and Model: Many Volvos
- Been thanked: 75 times
For not being a guy that specializes in Volvos he is doing OK. I notice that he left off anything about getting the ETM free from the intake line and I was groaning a bit when he fully removed the lower bolts on the intake manifold but that is just from experience.
The videos are well worth the time to watch. I am looking forward to the re-installation video and setting the pre-load on the CVVT.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
I just watched part 3 and did enjoy the lession.
- Year and Model: Lots
- Been thanked: 128 times
I particularly like this video. Great visual tutorial
- rspi
Contact rspi..
Valve stem seals can be replaced with the head on the block. You have to remove the cam cover, pull the cams, remove the lifters, then use a special compression tool to compress the valves springs, release the keepers, then pull the seals. A time consuming back breaking job but at least you don't have to crack the head gasket.
I seen the DIY thread on VolvoSpeed.com I believe.
- rspi
Contact rspi..
Crap, maybe I should have taken lessions from him. I pulled the battery, air box, and all kinds of stuff when I pulled my head.
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 111 times
OK -- I'll bite. If the valve stem seals can be replaced without removing the head entirely, then presumably a burned exhaust value can also be replaced without pulling the head, correct?
I'm asking since I currently have no compression in cyl. #3 in my '98 V70 and in lieu of a viking funeral, I'd like to try to replace the burned valve. This is a used engine with c. 69,000 miles on it which I had installed this past Spring.
Shop labor rates are prohibitive, so I'm tackling this as a DIY. It will be the most ambitious job I've done so far, and will have my brother's assistance. We recently did two complete PCV system replacements and have done axles, struts, innumerable brake jobs, etc., but I've never done a timing belt job and have never cracked into a motor.
Any mandatory reading/video watching before we dig in? Any advice?
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- Been thanked: 467 times
For 1993-1998 models, this is a very good tutorial:
Volvo 5-cylinder: How to Replace the Head Gasket
1999+ models has VVT but very similar.
- E Showell
Thanks cn90. I've seen the Tracy's material and thought it looked pretty good. I am hoping to do a much more surgical strike and just get in with the cams out and replace seals and perhaps one burnt valve or a broken spring. Hoping to do same in situ w/o removing the bottom portion of the head and thereby avoiding the entire head gasket aspect of things. To me, assuming that is all that is needed, it seems like a much more time efficient/cost effective approach.
'95 855 auto (sold)
'95 855 auto (sold)
