99 s70 hard start after gas fill up
duckman999
Year and Model: 99 s70
Post by duckman999 »
My 99 s70 starts hard after I fill the tank up. If I leave it running while filling it's fine. but if I turn the car off and then restart, I have to crank it a few time while pushing the gas peddle to get it running? Fuel filters replaced. Could it be the fuel pump?
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Try this:
https://www.matthewsvolvosite.com/forums ... =1&t=53800
I doubt it's the check valve in the fuel pump if it starts fine every other time except when just filled up.
Starts just fine in the morning?
'98 S70 T5
2016 Chevy Cruze Premier
Been thanked: 466 times
Post by cn90 »
Maybe some issues with EVAP system?
duckman999
It starts fine in the mornings. Just when fueling up
Post by cn90 »
EVAP issue.
https://www.matthewsvolvosite.com/forums ... =1&t=20589
I am jumping ahead, but if you decide to replace the Purge Valve, Google "Bosch 0280142300", and you will see that it is about $42 online.
duckman999
Thanks, I will look into that first. I thought the fuel pump change should be easy. But the pump in not located under the access plate in the trunk! It's about 6 inches off. So I would have to drop the tank to replace it.
duckman999
One more question. It the purge valve the one by the fan shroud?
jblackburn
duckman999 wrote:One more question. It the purge valve the one by the fan shroud?
Yes sir
'98 S70 T5
duckman999
Ordered the evap valve, only $44. Put it in last night, filled it up this morning.....problem solved!!! Thanks for your help!
jblackburn
'98 S70 T5
