Tracking down P0171
jtp
Year and Model: 99 v70R
Has thanked: 11 times
Been thanked: 10 times
Re: Tracking down P0171
Post by jtp »
Swapped out to a different IAC I had sitting around tonight. Old one was clean though. No stumble when I started it so that's promising since it's been doing that. Real test will be when the motor is ice cold tomorrow. Negative cable off to drain it and reset LTFT (thanks again to regent!!!).
Have been suspecting a broken fuel pump check valve but I pushed the schrader valve after shutoff and fuel shot out hard, so I think I'm set there.
Smoke test is on the menu for tomorrow.
99 V70R AWD
Almost 155K Miles
Breaking is how I know it’s working
98 S70NA (sold)
95 850 Turbo Wagon (RIP)
echase76
Year and Model: 1998 v70 T5m
Post by echase76 »
Pump the brake a few times and that drains it pretty good and then let it sit.
How are you doing the smoke test? do you have a home method?
1998 V70 T5m Silver/Charcoal - 150K
jtp
Post by jtp »
Smoke Pro Total Tech. Went in on a used one with my brother. If you are down in my area and want to give it a whirl just let me know.
99 V70R AWD
Almost 155K Miles
98 S70NA (sold)
jtp
Post by jtp »
No stumbling at all on an ice cold start this morning. That's definitely new with the other IAC motor in. Promising, but I'm not getting my hopes up.
99 V70R AWD
Almost 155K Miles
98 S70NA (sold)
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
I have seen issues with unmetered air from a sticky IACM (similar to vac leaks). Let's hope you've found the culprit.
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
jtp
Post by jtp »
Alright. So yesterday I noticed the that the vacuum line from the fuel pressure regulator wasn't quite kinked coming out of the regulator but was turning pretty steep. I put a longer line there and routed it with wide turns.
Also noticed two of the vacuum "caps" on the vacuum tree were cracking (6 months old, way to go autozone). Replaced those.
Between these two things and the new IAC the code did not pop up tonight on the way home from work like it should have based on before.
Too early for me to consider the issue done but really promising.
99 V70R AWD
Almost 155K Miles
98 S70NA (sold)
jtp
Post by jtp »
One more thing I did in case anyone is looking at this in the future. The tube from the PCV the plugs into the top of the valve cover was a little loose. I tightened that down.
Thanks again...
99 V70R AWD
Almost 155K Miles
98 S70NA (sold)
echase76
Post by echase76 »
jtp - love the Uncle Rico avatar. Hope you got your problem solved! My car also ran great today. Maybe it was because I pulled and opened the fuel pump relay last night. Or maybe it was the weather. Who knows.
Anyway, anyone know where can you find good vacuum caps? Everywhere I have tried locally has crap that cracks within a year. Seems like there is a market for silicone vacuum caps.
gswede
Year and Model: 850 R 1997
Post by gswede »
My PO171 was tracked down to a faulty TCV. Replaced it, deleted code. Have been running great ever since.
jtp
Post by jtp »
So it popped up again just now. Definitely took longer to come back this time, which seems odd.
I'll test for vacuum leaks today. It's just so stinking cold outside. All my vacuum leaks have always been p0172 though, and this is p0171.
99 V70R AWD
Almost 155K Miles
98 S70NA (sold)
