I still cannot find the cause of this vibration that occurs from a stop while accelerating to about 50 kmh (30mph). I’ve changed the lower control arms, ball joints, halfshafts, wheel bearings, inner and outer tie rod ends, struts, mounts, and strut bearings, stabilizer links, and the upper and lower torque mounts in the last year because they were all worn out. The car has 274000 kms on it.
I am installing a new haldex pump and filter when the parts arrive probably next week so I will have the driveshaft out and can check the Center bearing when I have it out.
Any ideas? Should I take it for a spin with the driveshaft out to see if the vibration is still there? Might it be the motor mounts, and if so, which one might cause this vibration. That’s about the only thing that isn’t new besides the brakes but they seem fine.
Thanks for your input.
Still tracking down acceleration vibration 2003 XC70 Topic is solved
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 117 times
- Been thanked: 271 times
2003 XC 70 (sold)
- SuperHerman
- Been thanked: 207 times
I think the propeller shaft is the most likely source, but it is hard to tell without driving the car.
The propeller shaft has three parts that can cause vibration - front CV joint which attaches to angle gear (here the grease gets hard and crusty due to age and heat from the engine and exhaust), center bearing (either the bearing goes bad or the rubber support), and the rear CV (usually not an issue). On some models the center bearing can be serviced, and the CVs can be serviced with a cleaning (search forum) or a replacement joint installed.
I think your approach is sound - remove the propeller shaft and see if the vibration goes away. While at it, assuming it does not go away, drive the car in manual mode, put it in neutral while at speed and determine if the vibration is still present, turn it to the left and right and see if the sound changes.
Report back.
Report back.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
I would also suspect motor mounts and subframe bushings, IPD sells bushing inserts that firm them up.Blacklab467 wrote: 24 Jul 2020, 22:40 I still cannot find the cause of this vibration that occurs from a stop while accelerating to about 50 kmh (30mph). I’ve changed the lower control arms, ball joints, halfshafts, wheel bearings, inner and outer tie rod ends, struts, mounts, and strut bearings, stabilizer links, and the upper and lower torque mounts in the last year because they were all worn out. The car has 274000 kms on it.
Check the motor mount next to the harmonic damper, they can collapse.
- jonesg
have you tried tapping the gas in drive , foot on the brake.
To see if the engine is shifting.
To me , the fact it occurs under load says motor mounts are another good place to look.
- - Pete -
- Has thanked: 81 times
- Been thanked: 178 times
Good advice above from superherman, as always.
Only thing I would add is if you went cheap for your CV axles they absolutely can still be ruled in as possible culprits. GKN/Lobro manufacturers the CV axles for P2 Volvo’s. Personally, I would pass on anything remanufactured or new & of less quality than GKN/Lobro.
I’m still running my original driveshaft, (both, f/r) CVJ’s & hanger bearing at 290k miles. I did replace the DEM pump in the last 10-15k though.
I have replaced both front CV axles with GKN/Lobro units, I believe around 230k miles.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
- gnalan
- Year and Model: 2001 S60
- Has thanked: 557 times
- Been thanked: 135 times
Sounds like you've changed a lot of parts. One thing I didn't see was new tires. Have you had your tires balanced lately? My front left wheel threw a weight, and it shakes like crazy. Just a thought I had, and getting your tires rebalanced shouldn't cost too much.
- Blacklab467
Yeah new tires last year, the vibration is on acceleration from zero to about 60 kmh, goes away when coasting and decelerating. I’m going to look at the mounts tomorrow, also remove the prop shaft because I have to replace the Haldex pump next week. I’ll take it for a spin without the shaft and see if it still vibrates and report back.
2003 XC 70 (sold)
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
I just tracked down a similar vibration the other day. It ended up being the heat shield on top of the exhaust manifold. Might not be yours but worth a try.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- Blacklab467
I think I might have found the problem yesterday. The right lower motor mount looks pretty bad and oil soaked. I have changed the upper mounts and transmission torque mount about a year ago. I will now order the two hydraulic mounts and the right lower and report back.
2003 XC 70 (sold)
- Blacklab467
Still having issues finding the vibration. I've removed the propshaft because I'm repairing my AWD so it is out of the car.
I've replaced the CV Shafts with Cardone units, had a similar vibration so received and installed a second set, still the vibration persists. Now I don't know if its the cheap CV's after trying two sets or if something else might be causing it? I've replaced essentially everything on the front end and all the mounts. I'm at a bit of a loss on what is causing the vibration now. I also took the bevel gear out to service it and change the fluid and it appears to be serviceable. Wondering if something inside the transmission could be vibrating but I don't really think so.
Any ideas? Thanks.
Any ideas? Thanks.
2003 XC 70 (sold)
- 1342 Views
Last post by SonicAdventure
- 1111 Views
- 1266 Views
Last post by jcdillin
- 932 Views
Last post by caprighia22
- 835 Views
Last post by 454cid
