automatic gear shift stuck
richard audet
- Year and Model:
with brake depressed gear shift won't move unless i activate the override lever. what should i do?
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
What model and year?
The interlock on the gear lever requires ignition 'on' (position 2) and the brake pedal depressed. If it won't work like this, the first step is to check the fuse(s). Depends on model and year as to which fuses are involved.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
richard audet
- Year and Model:
thanks, i replaced defective neutral safety switch and fuse and all is well.
