98 s70 strut mounts bad
Has thanked: 312 times
Been thanked: 818 times
I agree except to clarify, the spring seat is just a thick rubber bushing, there is no metal plate. It is the strut bearing or strut mount that looks like a metal plate. The only metal visible on the spring seat (on these cars) is a cylindrical collar in the center of it, that is fused to the rubber. The strut shaft goes through this collar and gets bolted down to it by the cross-shaped nut to hold all of the spring tension, then the strut mount slips over the top.
The fusion between the rubber bushing and the metal collar is the achilles heel of the spring seat - the cheapo ones fail right there very quickly and then you can spin the top nut.
Strut mount
Strut mount
strut mount.jpg (18.68 KiB) Viewed 532 times
pg_osborne89
Year and Model: '98 S70 / '94 940T
Post by pg_osborne89 »
Found this article pretty helpful as well. Short and sweet.
http://www.ipdusa.com/techtips/10031/sw ... s=P0,P4760
If you want to limit it's duties you can just call it a BEARING, but without it you couldn't MOUNT the STRUT to the car.
Just sayin...
