Car Details: 1998 V70 Wagon, 140k miles, Automatic
Weird problem that started recently and has me and my mechanic perplexed. The car sometimes won't accelerate as normal when starting from a stop. It almost feels like the brake is on or I'm pulling a heavy trailer. The engine makes a straining sound and the car will barely move. I also thought it might be trying to start off in the wrong gear but it sounds and feels like a different problem. The check engine light came on one time and the mechanic said it only indicated the fuel burn mixture was off and I possibly needed some new plugs. I know for sure the plugs aren't the root cause of this problem.
Other things I've notice: it only happens when the car is warmed up (+15minues of driving). The hessitation and straining noise during take off can last for a 1 -5 seconds at times. It doesn't do this very often but I've noticed it every couple of days. On one occassion, the car made a strange noise like gears grinding... hard to describe. It only did this once.
This problem has me thinking the worst..... TRANSMISSION Problems.
Could this be something to do the the control module that shifts the transmission? Can the tran. solenoid problem creat symptoms like this?
Many thanks in advance to the dedicated mechanics out there who help guys like me sort through these problems! Steve
1998 V70 engine strains and car hessitate on take off
White850Turbo
- Year and Model:
It alllmost sounds like a problem with the trans mode switch. Is the up arrow on the dash lit up?
-Sean
1995 850 Turbo (Extensively Modded)
1998 S70 T5 (Almost Stock)
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
Make sure you're not in "W" mode. It's not good for your car...same can be said for our country.
- 1051 Views
Last post by Volvo S80
- 223 Views
Last post by 02V70
- 1275 Views
Last post by peacelover60
- 15 Replies
- 3064 Views
Last post by erikv11
- 1040 Views
Last post by Oka
