S60 Drivers window has a mind of its own!
Tony1979
Year and Model: S60 T5 2001
Post by Tony1979 »
When I close my drivers window with the one touch closure option the window will get to about 3/4 closed then stop and go back down again. Sometimes it will close all the way and then go back down but if I don't use the one touch option and just use the up switch the window works fine. I just use the press and hold method but it is a pain in the ass!!
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Put the window up but hold the switch, it should go all the way up and hold the switch for 5 seconds after the window is up.
Sometimes that resets it
If not you either have a small blockage which the sensor is picking up or it will need to be fixed at the dealer on VIDA
Tony1979
Post by Tony1979 »
Even though it is an intermediate niggling problem, I'll give the 5 second trick a go next time it happens.
Many Thanks
JRL
Post by JRL »
You don't do it when it happens, you do it the next time you're near the car
Tony1979
Post by Tony1979 »
Ok, will do it when I leave for work in the morning.
JRL
Post by JRL »
Remember,, when you get in, put the window down then put it up by holding the switch up and continue holding it up after the window is fully up for a long 5 second count.
One-one thousand, two one thousand,etc.
Nothing to lose and sometimes this rests the window.
If it makes you feel any better once in a while mine does this too, the nature of the system.
As long as it DOESN'T do it most of the time ... I would not worry about it
Tony1979
Post by Tony1979 »
Thanks JRL it seems to have done the trick!
Thanks again!
