New Ignition switch and keyless entry issue
john200981
Year and Model:
Post by john200981 »
Just had the ignition switch on my 98 S70 replaced the other day...and now my keyless entry will not operate. Service guy said that the device would need to be re-coded to the igniton switch, but can't find anything on HOW to do it, or if it is a local Volvo shop visit I will have to do.
jabber
Year and Model:
Post by jabber »
I don't think you have a choice but to goto Volvo and get the remotes reprogrammed. I hear it's not cheap so let us know what the damage is if you go this route.
Jordan 1999 S70 Loaded!
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
You can do it yourself.
https://www.matthewsvolvosite.com/chat/p ... php?t=4352
The solution is about 3/4 of the way down the thread.
john200981
Year and Model:
OK...tried what was mentioned in the posts and it will not work for my S70. From further reading, I see that it will work for the 850, but the S70 gets the code some other way. BUT, being stubborn, am going to go and see if I can try it again.
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
I also have an S70...the only place to program the car to the remote (yes, in these cars that's the way it works) is at the dealer. Take all of your remotes into the dealer at once. Your car has to be set for each remote or else when you get home, the ones you didn't take with you won't work with your car. Up to 3 remotes can work on your car at once.
