2002 V70 XC- transmission drain/fill
tdorsey13206
Year and Model: 2005 S60 2.5T AWD
Post by tdorsey13206 »
Hello,
I am new to this forum and appreciating the great help it has been so far. I have a 2002 V70XC with 113,000 miles that I am preparing to do a transmission flush with IPD's flush kit and Mobil 3309.
I know on this car the lower hose is the one to use, but I have two questions hoping to get some help on...
1. How do you remove the plastic shield at the bottom of the car to gain access to the hose? I found the T25 torx screws, removed the small side panels and found the 10mm bolts on the sides for the big piece, but that's it.
2. Has anyone performed this flush connecting a hose to the upper radiator out port, in lieu of the lower hose? Seems like a simpler way to go?
thanks
jimmy57
Been thanked: 320 times
Post by jimmy57 »
The air guides in front of the subframe do not give you an access path. Remove the accordioned section fresh air hose from air cleaner box to top of radiator. Now grasp securely and pull up sharply on air cleaner box to remove it off the 3 mountings. Wire the air cleaner box to the rear and up. You can now reach the lower hose to compress clip and remove.
The plastic pan underneath engine and trans is secured with 12mm head bolts and when removed it will let the spilled oil drain down.
tdorsey13206
jimmy, thanks for your reply, I'll try working from the top down to get at the lower hose... about how much spilled oil comes out of the radiator once the hose is disconnected? are we talking put a rag under it? or a container? thanks again.
tdorsey13206
actually, not the big pan behind the structural cross member (and under the oil pan) but the smaller plastic shield in front of it... seems like if I could get this down, the lower hose would be right there.
castconcrete
Year and Model: 1996
Post by castconcrete »
Google "gibbons method".
otis44
Year and Model: 2006 S60 T5
Post by otis44 »
I've done several 2001 + Volvo's and have always done them by removing the upper line and installing the discharge hose over the line fitting at the cooler with no problems. Seems to me it would be much easier than trying to get to the lower line and would accomplish the same thing. I always use a hose long enough to reach the ground and have some type of jug there ready to catch the old fluid. I have always done it in 2 qt increments (2qts out and 2qts in), one person can do it, but if you have the catch jug marked for 2qts and someone to watch it, it is a little easier.
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 78 times
Post by chrism »
Otis44 is right on. That way you flush the cooler also.
PierreC
Year and Model: 2016 V40 / 2011 XC60
Post by PierreC »
On the 2002 XC you have to use the UPPER radiator / transmission cooler connection. The flow is bottom to top!
Pierre
Pierre
2016 V40 D4 VEA AT
2010 XC60 T6 AT
2015 V40 D3 (5 cylinder) AT [Gone]
2002 V70XC 2.4T AT - Elevate Stage 1 [Gone]
2007 S60 2.5T MT [Gone]
2002 S60 2.0T MT [Gone]
1996 850 GLT MT [Gone]
chrism
Post by chrism »
Our, to be on the safe side, should we just say best to examine the hose connections at the tranny and select the one that returns the fluid from the cooler to the sump?
Tonyx
Year and Model: 2001 XC70
Has thanked: 3 times
Been thanked: 8 times
Post by Tonyx »
On 2001 the upper hose is after the cooler. I also used clear tubing held to exit port on upper hose to pump out the old fluid.
2003 XC70 230K and counting..,
