1992 Volvo GL-Horn not working
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
creeposaurus
Year and Model: 1992 Volvo 940 GL
Post by creeposaurus »
Hello everyone. I've recently bought a 92 Volvo GL that runs very well for a car with 227k miles on it. Other than unexplainable stains that needed to be cleaned on the inside and a small trans fluid leak that need to be fixed and replaced, it works beautifully. The only problem that really concerns me is the horn not working.
I've checked the fuse and its alright, the horn itself is working (checked by connecting to a battery), but it seems there may be a problem with the wiring. I would be grateful for any suggestions or advice :mrgreen:
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Which model do you have? The 240 and the 940 both had the GL.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
creeposaurus
Oh my apologies! It's a 940
98T5
Year and Model: V70T5,98' / 940,93'
Post by 98T5 »
Same issue with my 940. relay is fine. voltage getting to horn from battery but still nothing from the steerting wheel button inside
98’ S70 T5 Turbo Manual - Midnight
01' S60 T5 Turbo- Brandy
98' V70 T5 Turbo - Swifty
93’ 244 n/a - Mr.Chill
91' 940 SE Turbo - Mojo SOLD
83' 242 DL - Bluto SOLD
93' 940 Wagon - Django - SOLD
:mrgreen: 8) :mrgreen:
stereomonostereo
Year and Model: 940 1993
Post by stereomonostereo »
Check the ground connection on the center of the horn. It's been the culprit twice on my 940
98T5
Post by 98T5 »
stereomonostereo wrote:Check the ground connection on the center of the horn. It's been the culprit twice on my 940
what is the torx size for the steering wheel and where can I find one that's slim enuff to fit in the holes on the back of the steering wheel?
stereomonostereo
If i remember right, it's a size 20 Torx. Any auto parts store should have one that would fit. You'll probably want to disconnect the battery first just as a safety measure. After you remove the two bolts, the steering wheel pad will come right off. It's connected to the wheel via a small ribbon cable. Unhook the ground wire in the center and clean both connections. That should take care of your problem
98T5
Post by 98T5 »
:D Lucky me!! I was fiddling around my toolbox trying to find a torx bit that would fit into the holes on the back of the steering wheel of the 940 , and lo and behold I find out this car came with a toolkit!!!, hidden in the right rear side panel behind a door with a turnknob on it. I opened it and the long torx bit I needed was sitting right there!. Volvo knew we'd need this thing for the steering wheel I guess. So I popped off the airbag, and yes my wires were everywhere and touching the metal on the back of the airbag. I tighten everything down with zipties and the horn works like new again! :D :lol: :mrgreen:
I'll post a pic of that torx bit when I get a chance. makes life so much easier.
