I've checked the fuse and its alright, the horn itself is working (checked by connecting to a battery), but it seems there may be a problem with the wiring. I would be grateful for any suggestions or advice
1992 Volvo GL-Horn not working
creeposaurus
- Year and Model: 1992 Volvo 940 GL
Hello everyone. I've recently bought a 92 Volvo GL that runs very well for a car with 227k miles on it. Other than unexplainable stains that needed to be cleaned on the inside and a small trans fluid leak that need to be fixed and replaced, it works beautifully. The only problem that really concerns me is the horn not working.
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
Which model do you have? The 240 and the 940 both had the GL.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
creeposaurus
Oh my apologies! It's a 940
Same issue with my 940. relay is fine. voltage getting to horn from battery but still nothing from the steerting wheel button inside
98’ S70 T5 Turbo Manual - Midnight
01' S60 T5 Turbo- Brandy
98' V70 T5 Turbo - Swifty
93’ 244 n/a - Mr.Chill
91' 940 SE Turbo - Mojo SOLD
83' 242 DL - Bluto SOLD
93' 940 Wagon - Django - SOLD
stereomonostereo
- Year and Model: 940 1993
Check the ground connection on the center of the horn. It's been the culprit twice on my 940
stereomonostereo wrote:Check the ground connection on the center of the horn. It's been the culprit twice on my 940
what is the torx size for the steering wheel and where can I find one that's slim enuff to fit in the holes on the back of the steering wheel?
stereomonostereo
If i remember right, it's a size 20 Torx. Any auto parts store should have one that would fit. You'll probably want to disconnect the battery first just as a safety measure. After you remove the two bolts, the steering wheel pad will come right off. It's connected to the wheel via a small ribbon cable. Unhook the ground wire in the center and clean both connections. That should take care of your problem
I'll post a pic of that torx bit when I get a chance. makes life so much easier.
- 3692 Views
Last post by MazdaDude
- 1470 Views
Last post by HereWeGoAgain
