Hey all , first let me introduce myself ..my name is Brett and i had just bought a nice running 4cyl volvo 244 automatic for 300.00 bucks with 125,970 miles.
1984 244 gl found out if I leave the battery hooked up it will be dead the next morning.. so I charged it back up and left it disconnected for 3 days and she fired right up so I did a test it with a meter and shows a 12v draw using the neg post on the battery and neg cable .. I see no light inside the car left on ... Any ideas I did the pull one fuse at a time thing and still a draw ..Thanks in advance
Brett
Dead battery over night
godfather1960
- Year and Model: 1984
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
Did you pull the 25 amp fuse in the engine compartment? It is on the left wheel housing by the ignition coil and covers the engine control system.
If that still does not show where the draw is then it is possible that the charging system is suspect. Disconnect/reconnect the connections on the alternator, one at a time, and monitor for drain.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
godfather1960
Great and thanks Bill i will check that out this weekend.. and get back to you
Brett
Brett
godfather1960
shows i don't have one but i did disconnect the alternator and still a draw i took off the skinny one first and checked and still a draw and then took off the bigger one off and still a draw are these both positive wires ?billofdurham wrote:Welcome to Matthew's Volvo Site.
Bill.
Open cicuit somewhere pulling down the battery. If you're leaving it connected the only thing I can think of that could pull it down is some auxillary item like a radio, ignition switch not fully turning off when you take the key out, or just a bad battery altogether.
I say, buy a new battery and try again. sometimes weak batteries just die on their own from sitting.
Also, check your starter connections to make sure they are not touching anything or grounding out.
98’ S70 T5 Turbo Manual - Midnight
01' S60 T5 Turbo- Brandy
98' V70 T5 Turbo - Swifty
93’ 244 n/a - Mr.Chill
91' 940 SE Turbo - Mojo SOLD
83' 242 DL - Bluto SOLD
93' 940 Wagon - Django - SOLD
godfather1960
Thanks,98T5 wrote:Open cicuit somewhere pulling down the battery. If you're leaving it connected the only thing I can think of that could pull it down is some auxillary item like a radio, ignition switch not fully turning off when you take the key out, or just a bad battery altogether.
thats all good but does not explain why i show a draw using the neg batt treminal and neg batt post
mikealder
- Year and Model: V70 2000
- Been thanked: 13 times
You will get 12V indicated on the meter if you connect it between the battery neg terminal and the cars neg wire as the meter is completing the circuit, what you need to be looking for is current drawn by setting the meter to AMPS with the test leads connected to the correct ports on the meter then go between the neg terminal of the battery and the neg cable of the car (obviously with the battery neg lead disconnected) - Mike
godfather1960
mikealder wrote:You will get 12V indicated on the meter if you connect it between the battery neg terminal and the cars neg wire as the meter is completing the circuit, what you need to be looking for is current drawn by setting the meter to AMPS with the test leads connected to the correct ports on the meter then go between the neg terminal of the battery and the neg cable of the car (obviously with the battery neg lead disconnected) - Mike
Thanks Mike.
i used the meter and got a 0.82 amp draw then checked it with a test light and lights up dim like a 6 volt battery would do to it.. the neg is disconnected
- regent
- Year and Model: 2015 XC60 T5
- Has thanked: 2 times
- Been thanked: 12 times
That's right. Your Voltmeter is working as intended
e. g. reading 12 Volts.
After you read the current draw (in Amps), continue by pulling fuses until the draw becomes acceptable (like something less than 30 mA) to narrow it down to a suspect group.
If the initial draw is 10 Amps or more, however, start narrowing down by disconnect the generator first to eliminate a faulty rectifier.
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
godfather1960
Thanks,regent wrote:That's right. Your Voltmeter is working as intendede. g. reading 12 Volts.
i pulled every fuse one at a time and i did disconnect the alternator and still a draw i took off the skinny one first and checked and still a draw and then took off the bigger one off and still a draw
