Headliner Fabric Seperating From Backing
obayha
Year and Model: V70 1999 Base
Re: Headliner Fabric Seperating From Backing
Post by obayha »
jreed wrote:Obayha,
Thanks for the tip. Hearing about the $66 brings tears of joy to my eyes! I was figuring it would cost more than $100 for a new headlining. Can you tell me which shop you used (I live near RTP) ? Thanks. :)
I'm thinking it was Shue's in Charlotte. The fabric wasn't a perfect match to the original, but then the original was hanging down everywhere :lol: .
(But is the board itself usually deteriorated, or being fiberglass is it mainly just the foam and fabric that are trashed?)
My fiber board was in great shape. Took a while to clean it up. I cleaned it up and stuck it back in, propped it up and drove 50 miles to Charlotte to drop it off and the same when it was done.
1998 V70 T5 331,000 :( Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
mercuric
Year and Model: 1997 850 T5
Post by mercuric »
obayha wrote: My fiber board was in great shape. Took a while to clean it up. I cleaned it up and stuck it back in, propped it up and drove 50 miles to Charlotte to drop it off and the same when it was done.
Nice, makes sense. Foam and fabric usually do deteriorate way faster than fiber stuff. That's good news.
Sounds like getting this taken care of is mostly about the time and patience to R&R the board rather than parts cost... Although I assume they'll be some $$ spent to obtain replacement plastic pieces considering some of them are already cracked before being removed... Probably space dust when I touch them!
I hadn't thought of it, but of course VIDA covers interior stuff too. Guess I should start reading all that stuff, get familiar with how it's all put together...
The "replacing headlining" section from VIDA follows. Interesting, they recommend removing the headliner diagonally through the front right door. This is from the "4DR w/SRS" section, matching my car..
Replacing headlining
Open sun roof completely
Disconnect battery negative lead
Remove:
Sun visor (2 screws) with holder (turn and pull out)
Front roof lighting panel (pry off lens with a screwdriver). See Electric motor and gear unit, replacement
Rear view mirror (2 screws). See Replacing rear view mirror
Front seal grab handles. Open cover with a screwdriver at the top and remove 2 screws. Insert screwdriver at the top and twist handle down.
Rear seat grab handles. Pry off lens with a screwdriver and disconnect connector. Otherwise same method as for front seat grab handles
B-post panel. Pull away. Leave the panel hanging in the seat belt.
Cantrail panel between A- and B-posts. Pull away
Cantrail panel between B- and C-posts. Pull away.
* Note! Retaining clip behind B and C-post panels. Remove carefully by the C-post.
Fold front seat backrests backward.
2 retaining clips at rear edge of headlining
Edge molding around sun roof opening. Pull down.
Slide headlining forward past C-post panels
Carefully place headlining over front seal folded backrests and dashboard
Cables on top of headlining (taped). Mark cable routing on headlining
Move gear selector lever to fourth gear or "L" for automatic transmissions
Adjust steering wheel: up and in as far as possible
Carefully lift the headlining diagonally through right front door opening.
Caution! Do not bend the headlining
Let's collect some neat threads as I hunt them down...
https://www.matthewsvolvosite.com/forums ... =1&t=26848
https://www.matthewsvolvosite.com/forums ... =1&t=34979
obayha
Post by obayha »
[Caution! Do not bend the headlining]
Duh!!
I guess at the right angle it should come out the door. They got it in there somehow. I put all the parts in different baggies and left them in the car.
[Edge molding around sun roof opening. Pull down.] If this doesn't break, you will of done a great job. New one was $60.00 for me. Old one shattered.
Shane
Rocky
Year and Model: 2003 xc70
Post by Rocky »
Go to a local upholstery shop and get a new one made up
98T5
Year and Model: V70T5,98' / 940,93'
Post by 98T5 »
Remove:
:shock:
that's crazy!! :lol:
98’ S70 T5 Turbo Manual - Midnight
01' S60 T5 Turbo- Brandy
98' V70 T5 Turbo - Swifty
93’ 244 n/a - Mr.Chill
91' 940 SE Turbo - Mojo SOLD
83' 242 DL - Bluto SOLD
93' 940 Wagon - Django - SOLD
:mrgreen: 8) :mrgreen:
mercuric
Post by mercuric »
It gets worse, searching around the boards, some people say good luck getting the board out the door without removing the seats too. This might be why some folks recommend getting it out the trunk. Seems logical enough to me.
RobTheModd
Year and Model: 98 S70T5M
Has thanked: 5 times
Been thanked: 7 times
Post by RobTheModd »
If you have a sunroof NEVER remove the headliner out the trunk.
It is very easy to remove the headliner out the front passenger door.
I have a detailed write up on it and would be willing to answer any questions.
http://www.floridavolvocommunity.net/fo ... php?t=1753
I have done this on many 850 and s70s. And will be doing a write up for a c70 coupe once i get to it on the wifes c.
Try not to bend the headliner board. Think of it like cardboard, once you bend it, it becomes weak.
RobTheModd
For the 850 it wont be much different from the write up i did on my s70.
Only big change is you may end up cutting the sunvisor wiring and reattaching that.
I would avoid removing it via the trunk on a sedan as you will have to bend it in order to remove it.
Simply chalk your wheel, slide the shifter all the way back and jimmy it out the front pass door.
Careful with the sunroof trim as you may break it. Roll it up and towards the center to release how it clips in.
The sunroof glass has to come out to do the slide.
Remove the 4 screw bolts, lay a towl down behind glass on roof, lay glass on towl, unclip shade, remove.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
If you cut the sun visor wires disconnect the battery first.
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Our 850 requires this but I am so putting it off. Looks far worse than an evaporator replacement. And stuff breaks, after 17 years of sitting in the sun.
