Soft top no chime at end of cycle demister not working. Help
yojason
Year and Model: 2004 C70
Post by yojason »
Help please!!!
I have an 04 c70 and I first noticed that that the rear window demister was not working. I have also noticed that the chime at the end of the lowering or raising of the top does not sound. Also the windows do not lower when the top starts its cycle.
From what I read on VADIS the control module is suppose to lower the windows 5cm at the begging of the cycle. Also the boot is not suppose to be able to be open via the switch (I can open it while lowering or raising the top but it does stop). Also the rear defroster is shup off when the cycle is not complete which is why I think the defroster does not work.
I have checked the fuses and they seem to be fine. I found a buzzard or Relay that reads "Audible Hood Warning Unit 8611543" I204
I am not sure if this is the relay for the chime. I tried to test it by putting power to the connectors but I did not hear a click.
Any help is greatly appreciated. Thanks..
Has thanked: 1611 times
Been thanked: 4072 times
(Removed incorrect post redirection)
yojason
Post by yojason »
I thought this was the right forum 2004 C70
Should it be a different forum?
My bad...I thought your 2004 was a P2 car...you are correct.
