Wheel bearing time...
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Re: Wheel bearing time...
Sweet, I'll do that. I really appreciate the help.
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 113 times
- Been thanked: 115 times
LoL!!!rspi wrote:Sweet, I'll do that. I really appreciate the help.
xHeart
cn90 reminds us, the torx bolt would strip if the socket is not seated properly.
- Been thanked: 471 times
rspi,
Buy a propane torch at hardware store ($12).
For every bolt and nut that is rusted, when you heat, heat the "nut" side (see RED arrows).
So in this case, heat the bearing side, exactly where the Torx bolts go in.
Heat it for a good minute, it will be much easier to remove the Torx bolts.
wheel hub assembly time for both my cars on the passenger side. both cars V70 and 940 are making noise from the hub.
oh goodie!
but I'm switching these things as needed, though some people do both sides even if one side is still quiet. I don't have that kinda time.
oh goodie!
98’ S70 T5 Turbo Manual - Midnight
01' S60 T5 Turbo- Brandy
98' V70 T5 Turbo - Swifty
93’ 244 n/a - Mr.Chill
91' 940 SE Turbo - Mojo SOLD
83' 242 DL - Bluto SOLD
93' 940 Wagon - Django - SOLD
- misha
- Has thanked: 152 times
- Been thanked: 402 times
There is no need to replace both of them if just one is bad.But usually...when one of them(on the same axle)fails,the other one will fail soon.There are no rules.98T5 wrote:...some people do both sides even if one side is still quiet...
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- rspi
Contact rspi..
Got my bearing in the mail today. Will PB Blaster be as good as the torch? I think I already have a torch around here somewhere.
I plan to do the job Monday. I'll need to go get the inverted torque bits. I got new bolts from FCP a few weeks ago. Looks like a straight forward job but I guess I should get a alignment afterwards.
I am planning a 4,000 mile road trip for the end of the month so I don't want to listen to a bearing all that time.
- rspi
Contact rspi..
I thought the link to VolvoSpeed was to CN90's instruction booklet. I'll search the database.
- Has thanked: 1503 times
- Been thanked: 3817 times
PB Blaster is only Defcon 3 IMHO.
Propane or MAPP gas is Defcon 2...definite step up.
You can try 50% ATF 50% acetone as in between. Don't get any fire around acetone, though......FOOOM!!!!
xHeart
I have replaced both front on my two cars with TIMKEN/FAG.rspi wrote:Got my bearing in the mail today. Will PB Blaster be as good as the torch? I think I already have a torch around here somewhere.
cn90 and Ozark Lee highlight two critical steps before you begin.
1) clean the torx head surface fully to help the socket seat, turn using pull pressure, do not slip. I stripped one, took me an hour to file away the bent torx edge. 2) it needs counter-hold, after removing axle I hand tighten at strut, and outer tie rod for support
Bolts pass through the knuckle and screw on to hub-bearing assembly, PB Blaster overnight would do the job using 1/2 " breaker bar. The exposed 3-5 threads at each bolt may have deteriorated.
I cleaned the knuckle back to metal before putting new one.
I would align.
- 25 Replies
- 6242 Views
Last post by Blacklab467
- 1615 Views
Last post by foggydogg
