I need a fix for an oil leak in a 1995 850.
The oil seals on the front of the motor are new. No leaks at the rear main seal.
I checked the pcv and it is clear.
I have so much crankcase pressure that I can see smoke comming out of the oil dip stick.
Can I add another crankcase breather to the engine to help relieve the crankcase pressure?
Thanks, Jim
1995 850 oil leak caused by crankcase pressure
- Year and Model: Many Volvos
- Been thanked: 75 times
When you say that you "checked the PCV and it is clear" what did you check? The Volvo PCV is much more than just a valve, it is an oil trap and several lines to the intake snorkel and the top of the cam cover. High crankcase pressure is almost always due to PCV issues.
The only way I deal with the PCV is to replace everything in the system with new. Both IPD and FCP sell PCV kits with all of the necessary parts. Unless things have changed the FCP kit is comprised of URO parts for nearly everything and I have had some serious trouble with the URO branded parts. Sadly the IPD kit also has some key parts that are URO but most of them are OEM. The last couple of systems I bought I also placed an order with my dealer of the OEM parts to substitute for the URO junk that came with the IPD kit.
The nice thing about the IPD kit is that they send real hose clamps rather than the Oetiker clamps.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Do a warm compression test, if that turns out to be good, replace the PCV system.
- Has thanked: 293 times
- Been thanked: 765 times
When the PCV was replaced, was the bottom drain port into the pan, inspected and cleaned out?
I assume the car is a turbo based on the compression numbers so: is the PTC valve clean?
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
The compression gauge must be off, those numbers are very low for a non-turbo. As long as that is the case the grouping is the key, a range of 20 isn't bad.
So was the bottom port cleaned?
And since it is a non-turbo, has the flame trap disc been thrown away (they get clogged really easily and cause increased pressure)?
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
cn90 created a modified PCV kit using a larger diameter hose to replace one of the stock size hoses that the kits come with. I can't find his write up for it now but apparently the larger diameter hose can handle more pressure from excess blow by gases. Might be worth looking into.
- Marcin
- Marcin
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 113 times
- Been thanked: 115 times
Look here https://www.matthewsvolvosite.com/forums ... =1&t=53448polskamafia mjl wrote:cn90 created a modified PCV kit using a larger diameter hose to replace one of the stock size hoses that the kits come with. I can't find his write up for it now but apparently the larger diameter hose can handle more pressure from excess blow by gases. Might be worth looking into.
- Marcin
- 20 Replies
- 3244 Views
Last post by scooterlovesvolvos3
- 12 Replies
- 5961 Views
Last post by erikv11
