Feels like clutch slipping, but I have an automatic. What?
hanseich
Year and Model: 850 turbo, 1996
Post by hanseich »
well, I'm more than happy to use the cheaper fluid if that's recommended. What advantages do you get from completely replacing with synthetic (ie: 3309)?
New to Volvo, already liking it. Hoping to keep it in good shape, not like the previous Benz 190e
Repairs so far: tie rods, outer CV Boot, air control flap, control rod, ABS module, various seals, motor mount
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
3309 is not a synthetic fluid, but it can help to smooth out harsh shifts or shift flares (where it revs up in between gears). Same goes for Mobil-1 ATF, which is a full synthetic fluid (but really, really expensive).
'98 S70 T5
2016 Chevy Cruze Premier
hanseich
Post by hanseich »
Dexron III is just your average "Walmart ATF" as far a I understand. I would never pick that, don't ask me why :-) I'll do a few changes, it would be nice if it fixed it.
(I have a few other repairs outstanding: valve stem seals, PCV, timing belt, CV boot. It will be a messy time.)
jblackburn
I would recommend the Valvoline MaxLife Dex/Merc fluid.
But here's a whole lot of people that know their oils:
http://www.bobistheoilguy.com/forums/ub ... 736&page=1
'98 S70 T5
wheelsup
Year and Model:
Has thanked: 16 times
Been thanked: 22 times
Post by wheelsup »
Personally I had better luck with the Wal-Mart supertech Dex III over the name brand Castrol stuff.
1995 850 GLT Wagon w/ 200,000 miles
Marcobrick
Year and Model: 2003 V70T5
Has thanked: 3 times
Post by Marcobrick »
Clutch packs do wear with miles, in cases where the trans has been overheated the linings of the clutch discs can break down. If there are dark non-metallic particles in the fluid this could be friction material. In a powerful car with worn clutch packs, slippage can occur. I'm not suggesting that your transmission has worn out clutch packs, but it's possible. What is your total mileage? Do you tow? Drive in town a lot?
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
1973 Land Rover Series 3 flat deck.
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1995 850 Turbo Wagon
1998 V70T5
Favourite line: "How hard can it be?"
hanseich
Post by hanseich »
@Marcobrick you just reminded me, that I did toe a pretty oversized trailer last winter for around 600 miles (1000km). Slippage started happening after that, not immediately, but some time after that. I generally don't do a lot of city driving, but I like to "play" with the turbo every now and then. It was after one of those instances that I could smell the burn and since then I can really feel some slippage.
Overall mileage is 136t mi, 220 tkm right now.
I take it pretty easy on the car these days, not to make the problem any worse, since I don't really want to do an overhaul of the clutch right now.
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
So, the truth comes out!
Towing with these cars (for that matter, almost any car) for long periods with no extra, aftermarket trans cooler installed is a recipe for disaster.
You can listen to all the hypotheses, your tranny is shot, sorry.
hanseich
Post by hanseich »
I always knew that something was wrong, I'm a pretty decent tech, and I know that something does not lock up properly. For now, I'll just do a fluid change and take it easy on the car.
Can I not change the plates in my tranny? Then I'd know at least that they are new. In a used tranny I never know how the condition all the parts are.
hanseich
Post by hanseich »
So this was the culprit. There was not much weight in the trailer, and it was in the deepest of winter, so I'm not sure how much overheating of the transmission oil would have happened. The tow went fine, although the roads were iced over, a heck of a machine that 850. (I actually think that kicking my the drive mode into Sport and enjoying the turbo was the main issue.)
(PS, yes, I know the hitch was set up wrong, but that's because of all those darn F150 on the road)
